Hi Gents,
I apologize if these are simple questions, but hopefully you have the patience to deal with another newb.
I'm building a kit car and haven't finished the wiring but need to get the PCM powered up. The main reason is I've bought a used PCM and I want to make sure it works. The second reasons is that despite using HPT I also need to load a trifecta tune that will eliminate the security since I'll have no BCM. I would like to get that loaded as well. Trifecta has assured me this will still allow me to tune with HPT so you'll be hearing more from me once the car is running.
To do this I am intending to wire up the GM LAN (OBDII port) and use a 12V power supply. Does anyone know if this is possible? From what I can tell I would need to wire it as follows:
Power to pins: 3, 5, 6, 54, and 56 on the small connector
Ground to pins: 1, 2, and 4 on the small connector
High speed LAN (+) to pin: 42 on the small connector
High speed LAN (-) to pin: 55 on the small connector
Nothing connected to the large connector
Is there anything else needed? Will the PCM throw up tons of error codes and puke or will it allow me to do this?
As I'll have no BCM is there any way for the PCM to calculate gear? I have a wiring diagram that I bought online that will allow me to run the engine in stand alone, but I see no wheel speed sensor so I assume that is part of the BCM. Can any tell me what pins on the PCM are linked to gear?
Thanks,
Daniel
