402 iron block
TFS 235
Super Victor intake with fast 4150 TB
42# green top injectors
SPEED DENSITY now
ok so a little back story... i just recently swapped from a fast 92 intake with fast 92 throttle body to the current setup... the car ran perfectly fine before swap... we have dialed in the part throttle table is pretty much within 2% and we were happy with that...
Now after we started dialing in everything above 4k rpm and PE.. the PROBLEM we are having is once it enters PE it goes pig rich(Bogging, fouling plugs) so we let out of throttle and the wideband just stays rich and you can tell its loaded up with fuel bad.. we have pulled 20% fuel out of everything above 4k rpm to try it out and and still does the exact same thing..... we are at a loss after changing plugs, wires, and checked fuel pressure 58psi key on and 58psi idling and driving
im attaching my tune setup for speed density, scan config and 2 logs showing the issues im having
please look over my tune and give me some insight
thanks
