Ideally you would dial in the fuel and ignition timing along with all off the attempted VCT breakpoints. This would obviously take an extremely long time to do properly but will give the best results. As cam timing changes so will cylinder pressure, So where changed cam angle shows less power it may have optimally put you in a better spot if the ignition and fueling were also dialed in.
