So got a turbo LSJ, all custom kit(no Hahn or zzp kit). Having idle issues. Currently has Mototron Deka 80lb injectors, had them flow tested today. Results- lowest-840cc(80lb/hr) & highest-852cc(81.1lb/hr) @ 43.5psi. custom intake manifold(similar to a Hahn manifold) with a LS4TB. Car does have BRFPR kit from ZZP. Set @ 52psi KOEO. I just scaled the Fuel/Injector Control tables from a Excel I found that Omega wrote here on HPT forum. I have the Flow Rate vs KPA scaled 63.5 across the board. Flow Rate Mult. vs Volts scaled 1.378. And just grabbed the offsets, pulse corrections and limits from Omega's Excel spreadsheet.
So my issue is the idle hunts really bad. Ignition timing is all over the place.
My first question is what are people changing the ETC Area Scalar to when going with the LS4 TB?
Then next did I scalar the fuel injectors right?
Then what fuel pressure would be recommended for best idle? I can rescale injectors if it is better to lower fuel pressure more.
Thank you.
