What table is used for the maf ?
both?
What is the difference between the two ?
I don't understand why there is 2 tables
both?
You want to use the Airflow vs Period on a coyote. The MAF Type should be set for Digital. These newer mustangs use Frequency vs the older ECU's which use AD Counts/Volts. Except for like 99-02 ECU's which uses clocktics.
2013 Mustang 5.0 A6
Procharger P1SC1 STGII w/4" pulley = 10lbs
DW 95lb Injectors
Lethal Performance O/R X-PIPE
Borla S-Type
2016 Ford F250 6.7L
Stock
Tank hou. So the mat vs v is useless.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
