HPT Employee
I'm sorry, I don't follow.
Do you have a manual or automatic car ECU?
Please list your results in the following format:
Your tested gear - Labeled gear in table
Thank you!
Car: 2004 SRT4
Transmission: T850 5 speed manual
tested gear in car physically: 1st gear manual
labeled gear: 1st gear automatic
tested gear in car physically: 2nd gear manual
labeled gear: 2nd gear automatic
tested gear in car physically: 3rd gear manual
labeled gear: 3rd gear automatic
tested gear in car physically: 4th gear manual
labeled gear: 4th gear automatic
tested gear in car physically: 5th gear manual
labeled gear: reverse manual
all other torque management/boost tables where set to not interfere with the boost by gear table to verify that it was working- first by going to wastegate only pressure, then a mid level boost setting (15psi), then a stepped boost calibration (wastegate 1st, 10psi 2nd, 3-5th 20psi) It worked like a charm.
I do hope this is more clear and of some help. Thank you for unlocking this table. Cannot wait to see what else you are able to provide for us. I appreciate it every time I go to drive my car.
HPT Employee
Thanks. Looks like I just inverted the order. The entire manual set should have been first. It will be fixed in tomorrow's build.
