Page 6 of 11 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 212
Thread: MPVI1 USB driver installation
  1. #101
    Dec 2009
    Ft. Wayne, IN
    70
    Got my drivers fixed, but not I'm running into problems installing the .NET framework. It says .NET 2.0 isn't compatible with a 64 bit system. I even tried installing a newer version of the .NET framework to no avail.
    This is driving my nuts. I can't find the email that Bill sent me with the beta download link either. Will that make any difference if I try to install that rather than the 2.22 version?
    2004 PBM M6 GTO
    Torquer v.2, Lingenfelter 243s, FAST 90, PTM 92, SVO greentops, SS OTRCAI, SLP LTs, Powerbond UDP
  2. #102
    Dec 2009
    Ft. Wayne, IN
    70
    Found this thread and solved the issue:
    http://www.hptuners.com/forum/showthread.php?t=30495
    2004 PBM M6 GTO
  3. #103
    May 2010
    FrankFort
    50
    I Have Windows 7 And Can't Get the .net framework to work on my computer. I have windows 7 64 bit and this doesn't work. I need This operating stat. Please Help ASAP...
  4. #104
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Quote Originally Posted by ls88foxbody View Post
    follow this step by step..
    http://www.hptuners.com/forum/showthread.php?t=5228
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
  5. #105
    28,278
    Sounds like you need to use the software version we posted without the net framework checks found here:
  6. #106
    Dec 2010
    Fort Worth, Tx
    104
    got mine working. I DL the link that Bill posted and also did the driver lookup from post #1
    good luck man.
    David
  7. #107
    Tuner in Training gpjohnny07's Avatar
    Mar 2010
    St. Petersburg, FL
    40
    thanks for posting this, i bought a new laptop and thought i wasn't going to be able to use it for tuning! saved my life!!!
    2014 Camaro 2SS/RS 6spd - Cold Air Inductions Intake
    Gone: 2007 Grand Prix base - Headers/HV3/FWI
  8. #108
    Apr 2011
    5
    I did everything the link said. I have a Dell with Windows 7 with 64 Bit os. I see the channels A and B working properly under the devices panel. I install the 2.22 VCM Suite cd and it says i need .net 2.0. When i try to install that it says i can due to using 64 bit. I'm about done with this whole kit. Been trying for hours now. Still getting no where. Can someone please help me out asap.
  9. #109
    28,278
    theres a link in the help section sticky to the version of 2.22 youll need to use
  10. #110
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    Although I found a link to it earlier in this thread, I wanted to bring the actual fix to light in here. My computer is giving me grief over the fact the drivers are unsigned. The fix for that is to reboot the computer and keep pressing F8 until the computer brings up your options. Arrow down to highlight "disable driver signature enforcement" and hit enter. Then work in your driver installation.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
  11. #111
    Sep 2002
    Chicago, IL
    6,397
    Are you using the drivers from this link:
    http://www.hptuners.com/pub/HPT_MPVI_Drivers.zip
    They are signed.
    We got this guy Not Sure, ...
  12. #112
    Jun 2010
    5
    I installed the software on my new laptop. I updated all the drivers for windows 7 64 bit system. When I plug in the hp tuners to the usb the sytem crashes and performs a memory dump. Any ideas on how to fix this?
  13. #113
    Aug 2011
    10
    so i can't get channel b to show up, any ideas?
    Running xp, have followed the guide 4 times and it will never instal channel b. The cable and MPVI are brand new, I haven't been able to use it yet...
    Suggestions anyone?
  14. #114
    28,278
    Delete the drivers and try again, eventually they will show up, if not contact support.
  15. #115
    Aug 2011
    10
    Ok I'll try a few more times. I tried 3 times already. I'll try more.
    Thanks.
  16. #116
    Apr 2011
    8
    Having the same issue. I've tired it probably 20 times now.
  17. #117
    Advanced Tuner Braciole's Avatar
    May 2008
    New Jersey
    227
    2007 C6 coupe LS3 416 6 speed mn Z51 3LT
    Vararam Snake charmer 160 Stat
    Kooks 1 7/8 headers with jet hot
    Fast 102 ported intake 102 TB RPM Level 5 T56
    MGW short throw ZIP 4.10 Severe Duty rear
    RPS TWIN DISC CARBON CLUTCH CCWs ele wp
    RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
    http://www.youtube.com/watch?v=PtOPy_lp2QY
    10.66 1.47 60ft 133+mph
  18. #118
    28,278
    Quote Originally Posted by Braciole View Post
    ...'s do not work in a link. You'd need the actual link.
  19. #119
    Jul 2007
    Honeoye,Ny. Boondox son. Shoot guns out my back door. noone cares.
    627
    Quote Originally Posted by Keith@HPTuners View Post
    They are signed.
    I have gotten the software to work fine with no framework issues on my new laptop.
    However it will not recognize the interface. I downloaded the signed drivers inthe link. unintstalled the unsigned drivers (even checked the delete box) then tried to install the drivers in the above link.
    Here is what she tells me:
    "windows thinks the driver you have are up to date"
    then I check the details box and it tells me they are unsigned.
    I keep following the instructions on the various threads on this issue with no resolution.
    Me love boost long time.
  20. #120
    Jul 2007
    627
    Update, delete every driver you can find relating to the interface. For some reason win7 64 will ignore an overwrite. You must remove them completly. Then download the signed drivers again, unzip and re-install. (you must tell windows to delete the driver when you unistall the interface)
    It is now functioning correctly.
