Originally Posted by
bluegoat06
You don't need to change your WOT fueling to adapt to AFR, 0.82 lambda is 0.82 lambda regardless of gas, e0, e10, e85, e100 etc. What you need to tell the pcm is the stoich ratio of the gas in use so the computer can precisely correct fueling for the gas in question.
Measure the content of alcohol in the gas, and adjust your AFR stoich accordingly in the calibration, correct your MAF period table if needed, and enjoy. if you're telling the PCM to shoot for .82 lambda at WOT, and your MAF period table is correct, you'll get .82 lambda at WOT, that's the beauty of tuning with lambda, you don't need to worry about AFR, just tell the PCM what's the stoich ratio is for the gas in use, that's the only time you'll worry about AFR.
I have a Silverado truck E85 ready from the factory, the sensor can tell what I have in the tank, so I only adjust the MAF table (equivalent of MAF period in our stangs) and voila, no matter what I fill the truck with, stoich moves around -2%+2% in CL, and my WOT fueling is .82 lambda in OL regardless of what gas I pump. we don't have a alcohol sensor in the Stang, so we have to tell the pcm what the engine is sipping, after that, the pcm does everything for us.
