recent ls1 swap in a c10, truck ran good for the first week and pulled pretty hard, noticed it started to bog under wide open throttle after about a week of driving. I took a few data logs and noticed its only commading 16 degrees of timing at 100% tps. we have it set at 26 degrees in those cells on the tune. ive adjusted the retard on the iat's to not pull anything until 120degrees or higher and haven't seen any knock retard. the MAF is unplugged for datalogging the ve tables. what could cause it to command only 10 degrees less than whats in the tune?
