my microsoft excel does not allow me to copy the values of the id850 injector data from the spread sheet.
i believe its due to the fact that it is not registered, not sure what happened their.
i ran across a tune file that supposedly had the right data.
flashed the car and now have trims of -10 - -15 percent.
it was posted by dsteck, the short pulse limit was not the same i wasnt sure why?
would someone be able to double check my id850 data in this file?
or does someone have a 2009 ctsv a6 with id850 data that they would be willing to share.
i like double check things when im not 100 percent sure.
I thought you had to make the OPEN LOOP gains table all set to 1.000 and the the closed loop enable tables to MAX (not allowing closed loop) to be in OPEN LOOP. I compared your file vs mine and those tables were different for OPEN LOOP.
Its actually ltft shut off with maf only.
I run it with no enrichment or adders and stft enabled because i tune part throttle with stft, just my preference really.i guess labeling jt "open loop" was misleading sorry.
The file you posted has id850 data? If so thank you!!!! On vacation so dont have access to my tuning laptop.
