knock retard finally came up on main spark-knock retard histo
ok so I finally got it to record onto the histogram this time and not just the gauge. Ok my log wont load but I saved some pictures not sure if I should just subtract timing in this area or whats going on
picture (1) is a little bit of retard picture (2) is how much the histogram showed at the end of log pic (3) and (4) is pictures of knock retard being on the gauges but not being recorded on this histogram and pic (5) is the areas I believe need the timing tweaked or somin is amiss I did notice my map sensor was always 70+ at time of kr
Reason: forgot a few works
Should post up your latest tune Chevypower101, so we can have a look at a few things ie timing etc, also what does your Charts look like in regards to KR when you playback, depends on your settings etc it will Register KR less than say 1.0* and you can hear it too..
