Recently had a V3 T Trim Supercharger installed on my 1999 Corvette and first thing I did was compare the tune files from before when it was N/A, till now. The way things will be discussed. (Before=N/A tune & After=Boosted Tune) The Shop that did the install, also did the tune.
My first question is about the transmission settings.
Before Shift Pressure and After Pressure stayed the same, however the Force Motor Current was subtracted by 98 from 0-90 shown in Fig. 1. I understand that the smaller input value results in a larger pressure output. But does the ECU monitor the Force Motor current table first, and neglect the Pressure table? I ask because I can tell a difference in shift feel(Felt it before I ever looked into the tune). I always had a soft 1-2 shift with my settings, but now with the new subtracted Force Motor Current values it feels like it should(Solid/Faster).
Fig.1 - Difference
Also in the Transmission Torque Management Settings, to achieve ZERO torque management should the General>Desired>Trans Desired Torque be maxed at 640? I ask because, Before I had it maxed, but now with the new tune it is zeroed out.
Fig. 2 - Trans Desired Torque
Second question...My VE table is the same Before and After, the only change on the airflow side is the MAF Calibration(I assume they calibrated it).
I understand that the VE table is used in the event that the ECU goes into a closed loop situation and/or references it compared to what is passing the MAF Sensor. But how can the VE not be changed under a boosted application? The PE enrichment value was fatten'd up as well as the Open Loop EQ ratio in some areas.
Third question...I think this was done as a safety precaution, but Before I had both "Spark Retard vs. Torque Reduction" and "Torque Loss% vs. Spark" set to 0. Now with the additional horsepower the new tune has increased the values for both tables. Figure 4 and 5 below show the tables in question.
Fig. 4 - Spark Retard vs. Torque Reduction
Fig. 5 - Torque Loss % vs. Spark
Can these be switch back to zero, and would it effect the Traction Control System?
