Hey Guys,
I am about to dip into my ECU and I am concerned on a few things that I am not 100% sure about yet.
First is the VCT function of the Coyote engine. I am confident in tuning the vehicle for for ignition advance and fueling, however the VCT function I am a little confused on. It appears the intake valve opening time reads in (-) values and the exhaust closing time reads in (+) values. According to the Ford PCM, does that actually mean advance VCT timing and retard VCT timing or is the negative and positive values cam angle adjustments based on TDC to the crank shaft and both VCT tables are actually reading in advance VCT. ( I hope that wasn't too confusing).
My other question is, tuning partial throttle. I have been informed mapped points during partial throttle operation are what to target for tuning, but what exactly would I be adjusting to better fuel economy, throttle response, and partial throttle acceleration? I am assuming ignition advance and VCT tables, because all fueling is targeting stoic and changes with the amount of load that is on the car.
I have seen a few dyno graphs that have really solid torque gains on the low end as well. I am wondering if VCT adjustments are made there as well or if its only fueling and ignition advance.
I have tuned various engines for years, however, none of them have dual VCT on both intake and exhaust cam, its normally only the intake cam. Bracketing cam angles are the best way to go to find the best intake cam advance for RPM break points. However, having control of both intake and exhaust seems like bracketing could be quite interesting.
Kris
