Guys,
Need some advice if you would be so kindly to help,
I have a 06 Cobalt SS LSJ 2.0 Turbo swapped with a precision 5558CEA and 80# injectors tuned on SD but for some reason the Tune is not following the timing tables. I copied the High to Low to see if it was using the low table and that didnt change anything. Other than needing to get a return fuel system for my injectors because of the duty cycle, i cant figure out why the timing is so off compared to the table. Unless im just having a huge brain fart lol.
Thanks for the help guys!
New.hpl
Cobalt SS Turbo Rev7.hpt
