Okay I have a 2008 cobalt ss turbo. With the DI lnf motor. I just recently installed a k04r turbo. (It's just a big wheel version of the stock turbo) got everything hooked up, and ready to go loaded a tune on to it, and it won't build more than 10 psi of boost. I thought I had a leak somewhere so I pulled all couplers off, and re checked all that. Checked the wastegate actuator vacuum lines, and made sure the electronic boost controller was hooked up. Nothing was out of place. I don't hear an exhaust leak so I don't think it's the turbo to manifold. Or the o2 housing that is leaking, so I looked over the tune. Couldn't find anything that would cause a problem. So I loaded a stock tune into the car with only 3 bar map sensors added, I noticed that the car is only allowing 50% throttle even when the throttle pedal position is at 100%. So I'm assuming this has something to do with the tune, does anyone have ideas what this could be? Thank you all for your help.
