I have an L76 crate motor, engine management components replaced and mild cam installed. Harness and electronic components from late '07 GM including E38 ecm.
Nelson Performance was hired (via email) to do the tune almost 2 YEARS AGO. It took close to a year to get the basics of the tune down but almost from the get go a slight vibration is felt from 1700 rpm to 2600 rpm. Although the engine smooths right out above 2600 rpm , the scan shows hundreds of misfires in #5 & #8 cyl. The rest of the cylinders show normal minimal random misfires.
Coils and injectors were swapped, plugs replaced twice, plug wires replaced with new, compression tested perfect, fuel pressure a constant 60 lbs., valve springs checked, flywheel/clutch checked, replaced harmonic damper, crank sensor replaced, all wiring traced and inspected, connectors checked and thee different ecms were tried with same results (all with the same tune).
Everything mechanical looks fine. The only thing strange or coincidental I have noticed was #5 and #8 cylinders are pinned next to each other on the ecm. I have tried more than a dozen times to do the relearn hoping that would eliminate one more possibility but cannot get it to work, even when dtc's were taken care of and misfire pids removed.
I have gone over this a hundred times with Nelson and they insist it is not tune related. I am hoping someone can clarify whether it is or isn't by looking at the tune and scan which I have attached.
I don't want to drive this thing until the vibration issue is dealt with for fear of hurting the engine.
Would appreciate some expert input! Thanks
NEW NELSON ECM 6-6-2015.hptNEW NELSON ECM 6-6-2015.hpt with misfire log.hpl
