Originally Posted by
miikezohsix
My wide-band worked fine after the install and cal process per the manual. Drove the car to work, got a good data log with real WB AFR numbers.
Drove the car home, and the WB was live, but never went below 12.0 or above 12.9, at least from what I could see with the numbers flashing.
I thought my placement of the module in the engine compartment might have heat soaked it or something, so I moved it further from the engine.
Let it cool, no luck.
On a whim, I re-ran the sensor cal process, with the sensor still installed, after the car had sat for 8+ hours, the process was successful, got good AFR numbers.
Took a ride, did a log, everything fine, AFRs at WOT matched previous numbers.
Played with my tune a little, started the car to drive home, and the WB is back to not going out of the 12's, though the car is running fine.
Any ideas about why I'd have to re-cal the unit after every run cycle?
