Results 1 to 9 of 9
Thread: hitting a wall at 6k rpms 08 z71
    Jul 2012
    7
    I keep hitting wall when i reach 6000 rpms. i have my rev limiter set to 6600 can someone point me in the way i need to look to keep from hitting this limitor?
    thankstruckBin1.hpt
    Tuning Addict
    Jan 2015
    6,802
    Not able to check out the tune right now as I do not have my laptop with me, but I would recommend that "all" of your rev limiters be checked... Even the oil temp and ECT temp ones. Quite a few tables just for the rev limits. There's even one that knocks your rev limit down if the engine is revving quicker than expected, so might want to zero that one out unless you want it for a safety.
    Sorry can't help more right now.
    ~Greg Huggins~
    Jul 2012
    7
    Could you give me a run down where all of these are? So I can double check
    Tuning Addict
    Jan 2015
    6,802
    Attached pic from your tune. Looks like your startup modifiers table is a good place to start. Then your accel based is the one that kicks it down if accelerating too quickly...
    ~Greg Huggins~
    Mar 2014
    231
    You're most likely going to need to adjust your transmission settings as well.
    Jul 2012
    7
    truckbin2.hpt
    i did a little playing in those tables listed... I am still hitting a wall at 6000... can someone walk me through this... I have been playing with it for 2 weeks
    Tuning Addict
    Jan 2015
    6,802
    Is it a rev limit or speed limit? I just went back and glanced at the pic I posted from your tune and it apears that you disabled all means of controlling rev limits... So one would think the problem would be in the trans cal?
    Does it sit there and bounce off of 6000? Does it just rev there and hold? Or is it just spitting and sputtering here and if you hold it, it will rev through? Don't do that long either by the way
    ~Greg Huggins~
    Jul 2012
    7
    It hits 6k and feels like the trans is slipping... until I let off...
    Nov 2009
    All Around
    3,149
    change start up modifier to say 6700rpm all table
    increase RPM cutoff to 6600
    also please attached data log
