Results 1 to 3 of 3
Thread: lnf:how to boost past 255kpa dal
    Oct 2014
    Is it true that our cars our hardwired not to go past 255kpa and if so how would I boost past that??
    No, but the stock 2 bar map sensors cannot read more than that. You need to get 3 bar sensors if you want to read higher boost levels.
    Dec 2008
    Nevada
    4,452
    Short Answer:
    The first part of that is a statement, "hardwired to pass 255kpa", and that is false. There is no section of the coding that sets a kpa limit on any tables or features. Yes you can boost well over 255 kpa if you want to learn how to tune first learn how to use the VCM Scanner Properly and read all the threads in the LNF Bible.
    I update the thread as needed and the link for it can be found in my signature.
    This ecu is like no other so ask all the questions you have and revive old threads if you have to.
