So there is minimum on time, secondary monitor, inferred rail pressure, inferred rail pressure low, and off duty cycle. What needs to be changed, if anything, in order to accommodate a return style fuel system?
Is it possible to run return on stock pump? I've already upgraded feed line to -8 and I'm ready to purchase regulator and return fittings etc. I was just going to plumb return line into the top of the factory hat. Have yet to take it apart to that level to actually see it, but I do know that there is plenty of room on the stock hat for a fitting to be plumbed on it. I just adapted the stock 3/8 outlet to a -8 in case any were wondering how I went from the 3/8 to -8.
