still not tracking desired cam position. tuning is all about receiving what you command, it should be something that is at least on your table primary list.
Mechanical parts seem to be all working as designed. Your not technically supposed to be over 8psi boost on a break-in period that should be around 900-1500 miles as requested by most machine shops. (3-5 tanks of gas) As for blowing, the answers is always unknown but if it was assembled correctly this thune shouldn't throw parts into the pan as long as you don't boost for medium-long periods of time. (Basically don't pull multiple gears and/or gears over 1st and 2nd as the duration and loading of the crank can effect the breaking seating process).
this looks much better.
Throttle body command is being followed by the actual position much better.
the maf and ve lb/min offset is more reasonable now. the other files there was just way to big of a spread.
max psi you pulled was about 18psi. I did notice however that pe did not initiate on that short pull. this would be something that would get corrected in the PE Enrichment table. gm likes to run them very lean and wait until 100% load before they really start doing anything. (time: 3.56.078)
Fuel Trim Average is close.
so far that's all I got, it looks like the gm tune is running how they all mostly run. fairly accurate until you ask for some express action on the go pedal and then the offsets and shenanigans start. very common for a GM tune to run negative or single digit positive ignition values at idle when its really programmed for like 25, and it will throw boost spikes up top when you let off. PE is delayed in a gm tune until you hit 100% load
and that's just not safe for a ton of wot driving like you would racing but for your break in period you will be ok since your not supposed to be there anyways. Once you get into tuning the file we can help you correct all of the GM errors.
nice video john, it clears up your description very well.
