Ok guys, here you go...
Optimum Spark tables. Absolutely the most misunderstood and neglected tables in the E69. I'm here to say these tables (along with many other obviously) are VERY POWERFUL when you figure out what they do and how they work.
I waited over a year for somebody else to figure these tables out, but to this date I've never seen ANYONE else using these tables for tuning. I actually don't quite understand it, we all begged and pleaded to Chris and Bill to give us more for the LNF E69, then when they do, tables like these are left gathering dust.
Here's basically what these tables can do-
Ign timing control at idle, where so many guys have had issues that they couldn't fix.
Ign timing control on cold starts, again this will fix all "Cat Warmup Delete" surging idle issues if you figure out how to use them. I'll post up a log of a perfect cold start and idle that my car has had for over a year on the stock and EFR turbos, straight gas and E47.
Ign timing control to eliminate the timing drop(s) that occur right before 3k and 4k rpms. Tune these tables right and the ign timing drop of 10 or 15 degrees will be GONE. No more dips in those dyno charts that pretty much every LNF dyno that starts the pull at 2k or so has. ( When I was trying to decide which vendor to go with on my EFR build, one of the vendors I didn't go with really wanted me to fix this for them. Unfortunately, I never did tell them how to do it.)
Ign timing control on decel.
Throttle control at all rpm's and loads. (Really.)
Boost control at all rpm's and loads. (Yep.)
What else am I forgetting? Not sure.
Here's a very short version of how these tables work. They're lookup/compare tables. That means they don't directly control anything, they're tables the ECM looks at and compares what it's seeing elsewhere to the numbers in these cells. For instance, if you have 20 degrees of ign timing in a certain cell, but the stock number was 2 degrees, the ECM will do this- (ECM talking here- lol) Ok, the main ign timing cell I'm in right now is requesting 20 degrees, but my Optimum Spark cell is saying something like 5 degrees in that same cell. So if my airflow says I'm making plenty of power (again, more lookup tables involved), and my Optimum Spark cell says I'll be making optimum power at 2 degrees, why do I need to go all the way to 20 degrees? I don't, I'm gonna run this cell at say, 5 degrees.
Here's what happens in another similar situation- That particular main timing table cell was at 20 degrees stock, but you've set it to 2 degrees in your tune. That particular cell in the Optimum Spark table is at 30 degrees. Again, here's the ECM talking...
Ok, I'm not making the power (or airflow) that's being requested of me, so I'm gonna look at my tables to see what I can change. Optimum Spark cell says I'd be making optimum power at 30 degrees in this situation. My main ign table is requesting 2 degrees, there's no way I can make the power that's being requested at that amount of timing, so I'm gonna bump that up to say, 12 degrees. (Again, lot's more tables we can't see that control the amount of range any table can have. There IS a limit to how much timing the Optimum Spark tables can control. When they get over that limit, they use throttle and boost to control airflow/power.) Back to the ECM talking- Ok, so if I'm still not making enough power at 12 degrees ign timing,
I'm gonna have to open the throttle more or give it more boost.
End result- you're NOT getting the requested 20 degrees that you put in your ign timing tables, and you're also NOT getting the requested airflow that you asked for in your DAL's, MALT or other airflow tables. Starting to see how powerful these tables are? Notice how these tables are in the "Torque Management" area instead of the "Spark" area? That's because they control torque more than they control spark directly. Lookup tables in any ECM are EXTREMELY powerful.
Here's a very simple analogy... The sky is blue. You're in charge of keeping the sky blue. Your "lookup table" says it's supposed to be blue. Somebody else made the sky blue, not you, that's another "table". You walk outside everyday and the sky is blue, everything's cool. You walk outside one day and the sky is green. You look at your "lookup table", it says it's supposed to be blue. Somebody changed that other guy's "table" to make the sky green. Your table says it's supposed to be blue or bad things are gonna happen, so you tell the other guy "Hey, I need that sky to be blue or we're gonna be in trouble!" He says "Ok, but this guy told me to make it green, so how about a compromise, we'll make it kinda blueish/green, Ok?" lol. Make sense? The problem is nobody got what they wanted. The sky is not green like the table was changed to, and it's not blue like the other guy thinks it should be. So now they fight over what color it's gonna be and nobody's ever happy.
That's the way these computers work. You can make changes, but you better make sure what you're doing is making all the other hundred tables happy. Otherwise they're all gonna fight each other and the car is gonna run like cr@p. As you can see, there are HUNDREDS of tables interacting with each other on these E69's. Anyone that says "tuning the LNF is easy" and "there's only a couple tables that everyone uses" is ignorant. Even I don't know all the table interactions on these E69's. Nobody does. Like I said, if your tuner says he's got it all figured out, RUN AWAY FROM HIM. I can guaranty he doesn't understand all there is to know about these four little tables. I've seen dozens of tunes from every vendor and professional tuner, I've NEVER seen a tune with modifications done to these tables.
Seriously. You put the wrong values in and here's what it can do- start and run perfectly at idle, run fine around town, but give it full throttle and IT WILL STAY AT FULL THROTTLE. Remember, the tables say "Optimum Spark", but they have a huge effect on throttle and boost also. BE CAREFUL! I can't stress this enough. These tables are powerful, way more powerful than the DAL table by far. You can make it so the throttle plate goes wide open at 1/8th pedal position if you want. You can make the turbo boost when you let off the throttle. You can make the throttle "latch", like I said above, it will not decel after you go past a certain pedal percentage. Basically, you could die!
