Results 1 to 10 of 10
Thread: NGX/AFX Wideband off .2-.3 on the laptop
    Aug 2010
    Hooksett,NH
    116
    Is there anyway to fix my wideband being off .2-.3 on my laptop? It is right off the battery for a good solid power/ground connection controlled by a switch.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Try a solid chassis ground, and log the voltage values during a startup of the wideband. Post the results.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Aug 2010
    Hooksett,NH
    116
    I removed the - wire from the battery (for the WB) and made a new solid down to bare metal ground for the WB.
    I did 2 scans (car in acc.)
    The first was plugging the green connector into the HPT and you can watch the WB start flashing weird then I switched the wideband on and it started its count down.
    The second was switching the WB on then immediately plugging the green connector into the HPT and waited for the WB to count down.
    WB stayed around 14.6 but the laptop states different.
    02 Regal GS
    Mar 2008
    St. Louis, MO
    4,859
    Looks like you still have a slight floating voltage on the ground. Is there an existing ground anywhere you can try? Any time I have similar issues (I have six total of these widebands that I use as portable), it always ends up being fixed by using a different ground.
    Aug 2010
    Hooksett,NH
    116
    There is not an existing one. I would have thought the battery was the best place.
    02 Regal GS
    Mar 2008
    St. Louis, MO
    4,859
    Surely the car had a chassis ground somewhere in the engine bay.
    Sep 2011
    Portland, OR
    518
    From the AFX manual:
    The AFX?s display is designed to show AFR values based on a gasoline scale with 14.57:1 AFR as the stoichiometric ratio
    In other words, the display you see isn't going to match exactly the number in the HPT log.
    The grounding is interesting. If I read it all correctly, you need to connect the analog ground to the battery as well.
    When utilizing the analog output feature of the AFX, always be sure to connect
    the system ground (two BLACK wires) to the same location as the analog
    SIGNAL GROUND (BROWN wire).
    I'm not sure why they didn't do that in the harness for us?
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Aug 2010
    Hooksett,NH
    116
    You are correct I wasn't thinking.
    02 Regal GS
    Aug 2010
    Hooksett,NH
    116
    Quote Originally Posted by RonSSnova View Post
    Interesting. I will have to look into this.
    02 Regal GS
    Feb 2006
    Canada
    1,958
    And switch to Lambda.... do it now before this AFR stuff makes you insane
    2000 Trans Am WS6
