I haven't tried 2.25 in a while. Is KR for the Oak ECMs working yet?
2007 Mustang GT
305ci big bore (5.0L Cammer block)
Ported heads
Lunati cams and springs
Usual compliment of bolt-ons
It has only been six months since they got DMRs working on the Oak PCMs so it will be quite a while before they will be able to get back to this. A couple of months ago Eric was able to get DMRs working on my Spanish Oak PCM but there is then the massive task of mapping the required DMRs to all the supported PCMs. Maybe Eric can advise an expected time or go and borrow and XCAL and use that LiveLink thing that we Ausys have to suffer with until it is resolved.
Eric has said "very soon" a while ago so I just was checking in to see if very soon happened yet.
I cannot add Wideband custom EIO input. I've got the latest beta. The instructions I found for .24 referenced a display menu, but I cannot even find that menu. Am I just stuck with the old version for now?
Thanks! Worked perfectly. FWIW, I was confused by all the old documentation out there telling how to setup a WB using menu display / table. I know you guys are as busy as you can be, I get that, but getting that documentation updated would have saved me from bugging you.
I have a 2008 GT500 and I know there are two IAT sensors, one before the intercooler, i.e. in fresh air, and another after the blower when the air has been heated by the compressor. I've heard the second sensor called IAT2. I cannot find anything like that in the channels for my car using the latest beta. Is it not available, or am I just looking in the wrong place?
I'm tuning the MAF for my 2008 GT500 using LTFT for CL and WB for WOT OL. I've done this years ago on other cars in the dark ages of tuning (twEECer) but I did it the hard way with my own excel sheets and plots. I completely get the concepts. I understand the scanner can build the histograms and save me from all the busy work. I've tried to read the forum but most of what I see talks about plotting "MAF Hz." In my scanner all I can see is MAF SAE (lbs/min which I can convert to g/sec) and MAF sensor which is the 0-5V signal. If anyone can point me to the correct "getting started" post that applies to my Ford vehicle it would be much, much appreciated.
@walt6076 in order to get the IAT2 to show in the scanner you will need to request it for your specific strategy/OS here in this thread or via [email protected]. I did the same for my 2010 GT500 specific strategy and they got it added in
I beg to differ. No need for an SCT Tuner on the older GT500s IF you request what you need to HP Tuners. If no one requests anything for certain years/strategies, there is no incentive for them to work on them. I requested a good number of PIDs and DMRs and given enough time HPT added them and I have now been able to tune with the beta 100% my 2010 GT500
For my 2008 GT500 (cm 0x7e0 spanish oak 1024k FBMM0c9.hex) can I get injector pulewidth and IAT2 (Manifold Charge Temp)? Thanks.
Any update on the 2015+ Mustang (GT) for Scanner info on torque converter status (and more on the transmission) as well as defining the labels on all the trans tables?
