Eric Brooks
HP Tuners, LLC
I cant add map points or any trans info. Copperhead 0X7E0 KTCR4A2 2014 f150 5.0
ETC Vacuum, ETC Throttle angle error, ETC Effective Throttle Area, and IPC Wheel Torque Error for the 05-10 mustangs when will we be able to log these channels
I will be adding these DMRs to the older Ford OAK PCMs ASAP.
Eric Brooks
HP Tuners, LLC
Can we get a Mapped Point PID or Status? As in, the PID is called Mapped Point and the value is the current Mapped Point.....
Could log into a graph mapped points based on whatever x and y axis we want to plot it out.....
Hi, I currently use the SCT Advantage Tuning Software and if I could get my 2004 Crown Victoria added, well, let's just say that you'd have a new customer. The SCT Software sucks!!
Thanks!!
in vcm editor I am having a problem, especially when you edit a file from Ford and problem when modifying the rear axle (( Final Drive Ratio))
The problem is that change does not happen to read the speedometer
my beta 2.25.2721
I'm sorry, I know this is the place to the problems with vcm scanner
Hey, I just bought this MPVI PRO (new) and am trying to get started. I've polled the vehicle (2007 F150 5.4L) twice and got the same result, about a dozen pids like OBDII stuff and that's it. I'm I doing something wrong or about to be extremely disappointed? The tables that I got using the VCM Editor were really cool. Looking forward to doing some work there, and hoping that I just need some guidance with the scanner. I have a small transmission shop and BIG plans for your tools.
Thanks for the help. I figured it out when I put my glasses on. LOL. Should have known better.
