I find myself wanting to say something like "Hi, long time listener, first time caller" LOL - I've generally been able to figure out any and all issues on the car by reading and testing rather than asking for help, so this is new. I read about half a billion threads and took a lot of time testing various things, but still having no luck.
I am having an issue with my GTO and was hoping to get some suggestions. See attached for current tune file, config, and log. Prob the best example of the issue I am referring to can be found between frames 2350 and 2500.
Essentially, when I let off the throttle after cruising at 60-70 MPH on the highway, DFCO will kick in and the RPM will drop down to 1100-ish for a moment, then it appears to exit DFCO and RPM will go back up to 15-1600 and hang there. This sort of prevents the car from slowing down much unless you apply the brakes. I can see the timing drop down to 3* or so during the DFCO entry, but then it ramps back to my normal cruise timing of 35-ish*.
I have tried lowering RAF in gear down to about half the desired airflow numbers where the car starts stalling, but it did not affect the RPM hang at all, so I put that back to my normal values. I thought it may be related to Throttle Cracker, so I adjusted those numbers considerably and if you look at the scan log, it shows around 0.035 lb/min during the time of the behavior I am referring to. It is even less than that now as I cut those values in half in the tune file since that log, but that did not make any significant difference.
Wondering if what I really need to be doing is tuning the DFCO exit criteria? Seems like the car should drop to a lower RPM even if DFCO was completely disabled, but that may not be the case.
The car has been tuned for both SD and MAF, but runs in OLMAF mode normally. I do not use closed loop at all. O2 sensors are completely removed except for a PLX wideband.
The car is a 2004 GTO A4
408c.i.
FAST 90
90mm TB
Trickflow 220
239/247 112 cam
1 3/4" Kooks headers
100mm MAF
3600 stall Billet Perfomabuilt converter (somewhat tight for a 3600 really)
Thanks in advance
