Are these supported?
Try reading it for starters, if you run into an issue email support.
was hoping for an answer a little more concrete than that before I tell a customer 3 hours away to come and I will "try and tune it - but I'm not really sure this is supported or not by HPtuners"
That's ok though because I have Tweecer also and can tune it with that if I have too - I just prefer HP
We've mapped out some of their operating systems but with ford there are likely more, best option is to read it and go from there.
Have the customer send you the PCM catch code and I can tell you for sure if the definition is done.
There is only one family for that combo (that i'm aware of for MY05)
BUP0, BUP1, BUP2, BUP3
4C7A-14C204-DD / The hardware is MTC-422A (which is used on 00-05 6.8 and F series with 6.8)
Cheers,
-Matt
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
ok. Thanks Bill.We've mapped out some of their operating systems but with ford there are likely more, best option is to read it and go from there.
Thanks Eric.. where is the PCM catch code?Have the customer send you the PCM catch code and I can tell you for sure if the definition is done.
so dose anyone have answer to this yet...i to have 205 ford excursion 6.8 v10 and would like to know ....thanks
