Once you apply the OS sd patch it will have these 3 tables in the pic below. These 3 tables are the one's that you need to populate in order to get it to crank and run.
If you have GM Ve in your scanner. Build a histogram that looks identical to these tables via rpm and map and log gm ve. AS LONG as your maf is close this will allow you to get closer and closer to what your ve table needs to be. I use this to populate my sd tables the first couple of times to "rough" them in as quickly as possible. Keep in mind that the "gm ve" is based off of the ve table and maf table in the tune, so if one of these isn't right, then what it tells you it should be won't be either - thus why you may have to do a few times... This is why you can't just use gm ve to get your ve table in one pass like some think you can in other words...
You can use the ls3 table I posted or this ZL1 table that might be closer for your build? Just start the engine and see how far off your initial a/f is while still in open loop and multiply the whole tune by this percent to get it rough to start datalogging.
