I have a 2009 cobalt 2.2 that has a turbo kit. I have 60 lbs injectors and im really confused on how to set them up here are the specs of the injectors any help appreciated
Coil Resistance: 12.5 Ohms / High Impedance / High-Z
•Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
•Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
•Gain: 0.11ms/mg
•Offset: 0.055ms
•Turn on time @ 14VDC: 1.14ms
•Turn off time: 0.85ms @ 600KPa
•Series: DEKA 4 ( DEKA IV )
•Orifice Type: Multi-orifice
•Spray Pattern: 30 Degree Spray Cone
•Factory fitted with Viton upper and lower o-rings
