Hey guys,
I have a L67 from a 1997 Regal GS in a RWD Locost-based car. Engine, and fuel/spark management are stock. Camaro 5spd behind it. Intake and full exhaust. Car is used for street driving and autoX.
I'm new to tuning, and I am hoping someone could look at my file and help with some questions. I've taken care of the DTC stuff, other than a couple I missed.
-First, why are my fans on all the time? I can command them off with Scanner so know they are hooked up correctly.
-In Scanner, my MAP reads 5psi at idle. Is there an easy tweak?
-Abuse mode and torque management- should I disable all this? (I have no A/T range switch, and no VSS. I forgot to check what gear it thinks it's in)
-AEM Wideband claims 15.3afr at idle. How lean do these engines run at idle? Short and long fuel trims are happy so don't know I believe that. It is possible I have an exhaust leak though.
-Anything else I should be doing? Not concerned about power yet. Just need to get it running well/safely first.
Thanks for any help.
Cory
