Hey all, it seems that lately my computer hasn't been allowing me to use the "Paste Special" feature a lot, so I created an excel sheet that can be used to calculate the MAF tables based on your calculated percentage of error. If someone posted this type of thing already in the past, I apologize. I created this because I needed the tool to help me out at the moment.
Disclaimer: Use at your own risk. I take no responsibility for how you choose to use this table. It is merely here as an aid. Feel free to modify for your own use.
To use:
Step 1: Paste the current MAF table in row 2, ensuring that it is accurately aligned.
Step 2: Paste the MAF % Error (Can be WB % Error, LTFT + STFT Error, whatever you use) from the log you have in your scanner. (It's okay if you didn't hit all the cells, the spread sheet will leave the MAF frequency alone if you have no data in that column.
Step 3: The NEW MAF row should be your calculated MAF value based on the percentage of error.
OPTIONAL: If you prefer to make less drastic changes to your MAF table all at once, you can use the optional Halfsy MAFsy table. That table is supposed to be setup to change the current MAF table by HALF of the percentage of MAF error.
I would appreciate any feedback that you guys may have to help make this table more accurate and better.
Thanks!
