Hey guys, I'm thinking my current 52lbs FIC injectors have some wonky data. So I've been contemplating buying some LS3s since the data is known and good there.
However, I came across the 47lbs GT500 injectors, which are medium length, EV14 injectors with USCAR connector (my current FICs are the same for the FAST 102 manifold and LS2 rail) and are much cheaper than new LS3s, especially with the spacers I'd need to run.
Anyway, my question is I found injector data for the GT500 (M-9593-G302) injectors and used DSteck's spreadsheet to get the data into the LS1 format. The issue is some of the offset vs. VAC vs. voltage data is negative. Is that okay? HPT of course zeroes it out, but I'm wondering if there is something I missed in the spreadsheet. I'd really like to use these injectors going forward as they sort of check everything off for me (assuming the spray pattern is good for the LS1?). Attached in the Ford data and the spreadsheet with the data entered.
Thanks for any insight.
