(To those new to this thread, I still haven't figured this out. Just want to save folks the aggravation of trying the things Ive posted below. Will update the thread once its working properly)
Wanted to post some screen captures of how I setup some tables for determining MAF correction using the 2.25 scanner on a Coyote. Can someone look at the example below and let me know if what is being captured will work for correcting my MAF curve?
The STFT table was modified the same. What I did was log LTFT/STFT via MAF Flow and Absolute load.
This is what I am getting for results using a minimum of 5 hits per cell.
This is a shot of the STFT using the same table modification.
Am I on the right track for capturing the % change needed to modify the MAF curve? I realize I need to do a bit of math to combine the LT and ST fuel trims.
