I have installed a new Comp Cams cam in my 5.3L 383 stroker. After the install, my ECM doesn't seem to like the new cam. I am getting the following new DTC's after the install. The cam specs are 620/610 113+2. I have attached the latest scan log, and config file used to scan with.
Thank you for your help.
4-29-15Scan.hpl09 Silverado CONFIG.cfg
[] P0101 - Mass or Volume Air Flow A Circuit Range/Performance (History) (Immature)
[] P0300 - Random Misfire Detected (SES) (Pending) (History) (Current) (Immature)
[] P1174 - Fuel Trim Cylinder Imbalance - B1 (SES) (Pending) (History) (Immature)
[] P1175 - Fuel Trim Cylinder Imbalance - B2 (SES) (History) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Incomplete
Heated Catalyst: n/a
Evaporative System: Complete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Complete
EGR System: n/a
