WOT high rpm limp mode
I'm currently chasing a limp mode issue. It only happens on wide open throttle with high rpm. The vehicle is a Gen F Senator with a lsx 454, vcm 16 cam, a Wippel 2.9l front intake blower, 3 bar map sensor and 102mm throttle. Trans has been built with a 3000rpm stall converter and 1200hp fuel pumps fitted from vcm. It drives perfect at 3/4 throttle any ideas would be greatly appreciated
I'd start with looking at raw TPS voltage, go over the top and
the trans will start short shifting and so on (because TPS is a
prime index for shifting behavior and TPS shows as not being
trustworthy if out of range). Stay under 4.7V to be safe, 10
seconds above 4.75V will set a TPS high code but any time it
is over 4.75 it will baby the trans just for safety.
