Results 1 to 4 of 4
Thread: VCM controls- reset/on/off trims
    Tuner Widebody06's Avatar
    Mar 2014
    annapolis MD
    116
    VCM controls-does reset/on/off trims all work?
    My question is do the on/off fuel trims options work? I know reset seems to. If the on/off works, is it persistant or only active for that run?
    Am I missing something?...I see no indication that any given control has worked. You click a button and then its back to the way it was...
    '06 BOM M6 Widebody RA6 GTO
    Trick Flow 550 kit( 225 heads, Track Max cam, springs, chain etc)
    ARH longtube , MBS HiFlow cats, Corsa Touring X-pipe SS exhaust
    Wilson FAST 92mm manifold #42 DeatschWerks Injectors soon
    Vararam Intake Duspeed not installed yet
    B&M shifter 3.91 rear,Monster level 4 Harrop diff cover
    CTS-V V2 brakes BC BR coilovers Whiteline everything
    DSS AH axles, Spohn LC arms, Toe Bar
    CCW 505a 10.5x19, 12.5x20 Nitto Invo 285& 345
    SCSS oil & afr Innovate LC2
    Jul 2013
    Huntsville AL
    164
    For my car the controls were backwards. On is off and off is on.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by Widebody06 View Post
    The open/closed loop buttons worked for me, and the fuel trim reset worked also.. so they worked for me
    It's easy enough to log fuel trims and see what happens when you hit the buttons.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Mar 2014
    annapolis MD
    116
    and the answer is, experiment and see
