Okay, in an attempt to be on the safe side and reduce knock, here is what I came up with. I still think I could go a bit leaner, but I'm looking for opinions on this.
Keep in mind i'm running 12psi and an Alky kit. Hence, the reason for a sloped AFR.
0-2000 - 11.75 AFR
3000-4750 - 11.51 AFR
5350-8000 - 11.30 AFR
And this is BASE afr, not accounting for the difference of the meth.
I smoothed the transitions throughout the missing RPM values. I'm seeing through my WB the methanol having anywhere from .5 to sometimes 1 full point afr to the rich side. Usually between .5 and .75 when meth spraying.
Any thoughts?
