Results 1 to 11 of 11
Thread: 2015 mustang timing question well a couple
    Apr 2015
    6
    Let me start by saying im really new at ford tuning. I have a 2015 mustang gt that I plan on spray a 150 shot through. Where will I find the timing tables to be able to take a few degrees of timing out of this thing. I data logged it and it showed to have 24 degrees at wot at 7k. Also I read about changing the lambda but again I cannot find it. Sorry if I just missed it somewhere but I really have searched.
    Jun 2008
    Tyler/Longview, TX area
    746
    Your max spark tables are in Engine > Spark > Advance > MBT Spark (all 28 of them). Your spark timing tables are in Engine > Spark > Advance > Borderline Spark(again, all 28 of them). Plus there are lots of tables that advance and retard timing based on temp, load, iat, etc. to give you your final timing.
    Lambda is in Engine > Fuel > Open&Closed Loop > WOT Fuel. Good Luck!
    Wait are the mapped points 0-14? Do I need to change all of those or just the optimum tables?
    Jun 2008
    746
    On 11-14 Coyotes OP is what's used for WOT. On 15, I'm not sure as the OP tables are not active on the Mapped Points Config table. Maybe someone with 15 experience can chime in.
    Quote Originally Posted by txcharlie View Post
    Ok thanks txcharlie I have a 13 and was confused because I thought I read we just changed the op tables on the 11-14, thanks
    Jun 2006
    Rham, NC
    155
    I have a 15 gt on a 150 shot of nitrous and I enabled the OP table in the mapped points on mine. I also changed some timing adjustments in the lambda spark correction along with cam timing changes (doesn't seem to respond anything like the earlier coyotes did though).
    Apr 2015
    6
    how did you enable the op table? I played with the op table and couldn't get the car to reduce timing at wot.
    Jun 2006
    Rham, NC
    155
    Under variable camshaft, there is a Mapped point table, that is where you enable the OP mapped point.
    Current toy- 97 SCSB OBS chevy forged 6.0/4l80 combo with a bit of boost..currently back under the knife
    To many previous vehicles to list
    May 2015
    427
    Quote Originally Posted by toyoguru View Post
    Have you experimented with VCT advance and retard to try to find hidden power?
    Kris
    Mar 2013
    45
    your 2013 and your 2015 cam timing will be different as you are dealing with imrc now in the 2015 you dont have for 2011-2014.
    May 2015
    427
    I'm sure it's different advancement but I guarantee there is power there somewhere.
