Results 1 to 4 of 4
Thread: DBW to DBC trans question and MAF
    Tuner JHPerformance's Avatar
    Jan 2014
    Central KY
    95
    Drive by wire harness and PCM with the IAC stepper motor chip, 06 express 6.0 4l80e
    Can I keep my stock engine and trans file and just convert that file to cable drive? If so how much is required to do that? I know that the trans and all is tied into the throttle body.
    Or would it be easier to find a DBC 6.0\4l80 file and flash it all over and rework the harness accordinaly?
    Will my 06 express MAF work with the 99-02 tune or will I have to repin and use 99-02 MAF?
    I am catching bits and pieces I just want to know a definite answer. I would prefer to tune out the DBW and use my factory engine and trans file, but I don't know what is required to do that.
    Thanks!
    Jake Hatfield
    Central KY
    Tuner Howes's Avatar
    Apr 2015
    NH
    130
    here is a stock tune file for an 02 lq4 25hd to try .
    Jan 2014
    Central KY
    95
    Quote Originally Posted by Howes View Post
    Thanks Howes. Can anyone confirm if the MAF will have to be changed?
    Jake Hatfield
    Central KY
    Apr 2015
    NH
    130
    your 06 express maf
    Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor
    Pin
    Wire Color
    Circuit No.
    Function
    A
    YE
    492
    MAF Sensor Signal
    B
    PK
    139
    Ignition 1 Voltage
    C
    BK/WH
    1551
    Ground
    D
    TN
    472
    IAT Sensor Signal
    E
    TN
    470
    Low Reference
    then the 02 silv
    Pin Wire Color Circuit No. Function
    A BLK 552 Low Reference
    B TAN 472 IAT Sensor Signal
    C BLK/WHT 451 Ground
    D PNK 239 Ignition 1 Voltage
    E YEL 492 MAF Sensor Signal
    these are your pinouts. don't know the rest of compatability sorry.
