I have updated my vcm 2.24 & 2.25
and still there is no pid for knock ???????
how to read it ?
2014 ford raptor 6.2
how to read it ?
Using the 2,25 scanner? I just begin using it and you have to select every sensor PID from the lists and for the mustang KR is working just fine tomorrow ill check on a 2014 raptor maybe is a bug why need to report
all the way from Tampico bay Mexico
Does KR work in 2.24 scanner? Working on a 2007 mustang and the only PIDs I can select are Knock voltage 1 and Knock voltage 2. If I have to use these PIDs, what is the knock threshold in volts?
CSR
Hmm. I switched to 2.24 from the beta because I wanted to export data into a spreadsheet, which is functionality that doesn't exist in 2.25 according to the "2 weeks" box I get when trying it. I'll look for KR in 2.25 then.
2007 Mustang GT
305ci big bore (5.0L Cammer block)
Ported heads
Lunati cams and springs
Usual compliment of bolt-ons
I downloaded the latest 2.25 but still can't find a KR PID for my 2007 Mustang. I have Knock volts for sensor 1 and sensor 2, but that's all I see. Am I looking in the wrong place for the KR PID?
2007 Mustang GT
Ported heads
You could try doing what ElecTech says about deleting the file in this thread.
http://www.hptuners.com/forum/showth...ord-Tips/page4
I have a feeling the knock DMR hasn't been added to your OS yet. Last time I checked 2.25 I didn't have it either, but it has probably been over a month.
2007 Mustang GT
Ported heads
