Results 1 to 3 of 3
Thread: GMPP 480hp LS3 with computer and harness Idle issue
    Jul 2005
    29
    Has anyone had the isssue of it idleing at 875 no matter what you set all the idle rpm tables at?
    Even the scanner shows its calling for 750 and it idles at 875.
    Nolan
    Tuning Addict
    Jan 2015
    6,814
    Typically either your main timing table is too high in the idle areas or your airflow min is too high in those areas. Could also be the idle airflow proportional table being set too high as well, but usually it's one of the first two. Check timing first. Try taking some out with scanner controls to see if it comes down any.
    Hope this helps.
    ~Greg Huggins~
    YES.
    Check out this thread, I posted starting at #185.
    http://www.hptuners.com/forum/showth...wn-idle/page10
    I gave up on trying to "fix" it because it runs ok, but it still baffles me.
