When you load your cal to the computer for modifing, how do you know which program you are modifing? The one the car starts on or the competitive mode one?
base file. comp mode is a select set of features that are aside the base mode. In vehicles like chevy trucks and pontiac gtp's the comp/tow mode only holds the gears longer and shifts a few tables from a stock map to a high performance map. its like having two tune options in one file. LNF/LDK/LHU it only eliminates traction control and in some versions will allow you to have a no lift shift option. these motors dont have dual table setups like the multiport injection motors do.
Ok thanks. Just building a 2.5l and it's going into a solstice. Fairly serious project. Ill use vcm suite too.
very cool let us know if you have problems. everyone here is very helpful.
