Results 1 to 8 of 8
Thread: MAP/KPa not matching PSI? also does e85 help with engine cooling?
    Oct 2014
    26
    1. My scanner shows 14.xx psi which is confirmed by my mechanical boost guage.
    but when i looked at the logged Kpa its only at 149?
    shouldnt it be maxxed out or closer to 210kpa at 14 psi?
    whats the deal with my map reading?
    also it was really hot today and got some loging done. ive noticed that on a stop and go traffic where it consist of mostly stop. the ect goes up to 225* this is when im holding 4k rpm and not shifting like im suppose to.
    pretty high due to heatsoak. the temp is way below on the freeway or when its not super hot.
    Im wondering if running e85 will aide a bit with engine cooling? aside from going all out on cooling stuff.
    Aug 2012
    SV, AZ
    447
    No one can help you without at least the log you're talking about. e85 will cool the air charge but will not help with engine cooling.
    Oct 2014
    26
    Quote Originally Posted by Eaglegoat View Post
    ops right sorry. editted and added log.
    and if the combustion chamber is cooler from e85 vs 91 wouldnt that contributed to lower temp?
    im considering e85 for other reason but i was wondering if this would help as well. id rather change over now vs later if it will.
    Jan 2014
    Australia
    1,981
    when i changed to E85 i had read that it helps cool engine temps but i havnt seen any change at all the engine is still going to run at the temp of the thermostat, intake temps are little better tho
    Aug 2012
    SV, AZ
    447
    Quote Originally Posted by tuned2boost View Post
    E85 results in more fuel being burned for the same amount of air. Even though there's less energy in each molecule there are more molecules. Therefore more total energy in each combustion event. That energy is heat/pressure therefore it cannot help with engine cooling.
    The ethanol has a lower vapor point than gasoline . As it is injected into the port it vaporizes/evaporates which pulls heat from the air, coolong it.
    Oct 2014
    26
    thanks for the reply guys.
    anyone know if my map reading needs calibration? or is that what its suppose to read?
    Oct 2014
    26
    bump
    Tuning Addict
    Jan 2015
    6,802
    Boost Pid is in VCM scanner board. Only works if your map is reading correct baro though.
    ~Greg Huggins~
