P2135 and p0651 help
hi , i just install a new gmpp harness and ecu for a ctsv motor .
the engine run first time no problem , then after couple rpm revolution i got the engine code p2135 and p0651 ... i try to erase them but the car still run on limp mode ... , i try to replace the throttle body because i read here it could be the problem but i still have no throttle pedal and still run in limp mode ? any idea ?
thank
I would pin out the harness and ECU and see if it is right for the TPS connection....
i have no 5v at my throttle body ? i found a loos ground on the engine from the batterie , i think the engine lost is ground and take the ground from the arness and the ecu conection and burn the ecu driver ? it is possible ?
