Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
Thread: Permanent Code problem
  1. #41
    Jul 2012
    34
    Could some confirm or deny my scenarios, or provide a better answer?
  2. #42
    Jun 2018
    4
    Hello all, new guy here having similar issues. Seems if I set po420 & po430 to 3-no error the catalyst monitor goes to complete and does not reset. This is a problem because the emissions inspectors check that they reset. Also, the codes are still in there as permanent. Hopefully someone with more knowledge can help with this. I am stuck because I can?t get plates without emissions passing. I need to drive to get emissions to pass. I can get temp, but it?s limited so I need to get this right first. Thanks
  3. #43
    Sep 2016
    Phoenix, AZ
    109
    Quote Originally Posted by jman3794 View Post
    Sounds like possibly setting codes to no mil reported and drive cycles fixed the issues for some of the guys in the post. Sounds like it took quite a bit of time and cycles for some.
    07 Silverado 5.3 full exhaust, CAI, BTR Stage 2 turbo cam and springs 226/231 .605"/.598" 113+4
  4. #44
    Nov 2019
    2
    I had the same codes on mine. To fix it I bought the anti foulers and put them on the rear 02 sensors until the code clears. After the code clears I changed the dtc to no error reported
  5. #45
    Jul 2022
    2
    Having same issu on Suburbian 5.3 Flexifuel, tested write cali and full, they are still there.
    There is already adaptors placed, and still got the codes.
    So, any pro tip for this weird stuff thats happening for many people.
  6. #46
    Jan 2014
    SoCal
    1,578
    Quote Originally Posted by NordicTuning View Post
    So you want P0420/30 to pass right?
    Does it have the cat's on it, and downstream O2's? That's how you will get the permanent codes to clear. Otherwise they never will.
  7. #47
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    475
    Stuff the rear adapters with coarse steel wool.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
