Deatschwerks 65lb injectors
According to http://www.deatschwerks.com/products...-0065-8-detail these injectors actually flow 72lb @ 3 bar and 86.2 @ 4 bar. Is this correct? Right now the car has the IFR set to 86.2 and fuel pressure is @ 58psi and even with the vacuum line unhooked it is completely lean and adding about 25%. Obviously I would assume an injector rated to 65lbs should be @ 3 bar and IFR should be set to about 75lbs.
Is this wrong or right?
The flow sheet that came with the injectors says it flows 737cc @ 3 bar. Guess that works out to about 851cc @ 4bar(closer to 80 lbs).
