Originally Posted by
LSXtreme
The timing is doing exactly what its supposed to do at that RPM/g/cyl and IAT. Your IAT is 124* (which is pretty warm) so its pulling 3* out of your base table. Without a stall your going to hit low timing numbers at that RPM and WOT. For starters, with that cam you should be idling around in gear 750-850 rpm and 18-20* of base timing. I know it seems high but without a stall and no tq that low its going to fall flat on its face (like its doing) idling around 700 and hammering it to the floor. Plus it will idle a little cleaner. Smooth your High Timing map so there isnt any peaks or valleys. It should have smooth transitions. Once you have the High table cleaned up, copy your high table to your low, select the whole map and remove 3 degrees out. Copy your low table up to 4800rpm and paste it in your In Drive and In Park Idle Spark advanced tables. Select the whole table on both and take another 2 degrees out. This way your spark only has a 5 degree window everywhere.
Try to not let the car sit and heat soak before you test again so the IAT isn't pulling any timing out from it being too hot.
