Results 1 to 8 of 8
Thread: injector data for e40
    Aug 2012
    SV, AZ
    447
    Dsteck could you be awesome and do your thing for GM#12609749. I need it for an 06 GTO. If you have the time I also could use it for a 2002 firebird. I trust your conversions on this more than my own. Thanks.
    Aug 2012
    SV, AZ
    447
    My biggest problem is that I'm having trouble finding the correct base data to use for calculating. If someone could verify for me that the data I'm using is the correct data I'd appreciate it 1326469394.hpt. I was told they are 54ish LB/hr but all the data I'm finding puts my own calculations as 49.9510975217954 LB/HR @ 58psi with no KPA correction. Thats as far as I've gotten at this point. I've got a pool party to go to so I'll be back later to try and muscle through the KPA corrections, the offsets, and the short pulse adders.
    Aug 2012
    SV, AZ
    447
    I have 3 distinct sets of data that I'm coming up with. The flow rate is calculated from pressure change in the 59.2 PSI/408 KPA cell, the Poly flow is the from a 6th order poly fit, and the flow rate 2 is from pressure change in the 56.3 PSI/388 KPA cell. All are corrected to a 58PSI/400 KPA base pressure and for Manifold Vac.
    Manifold Vac 0 40 80
    Flow Rate 49.9479450803468 52.3858467481845 54.7152324430702
    Poly flow 49.9681581278773 52.3563963285721 54.5956321042661
    Flow Rate 2 49.9127399230347 52.3489232676943 54.6766671254695
    This is obviously just a sample to show the differences. It's the higher KPA areas I'm most "concerned" with as they are the startup/idle/low rpm driveability areas. Is this too small of a difference to really matter? I try to be as precise as I can with things so I have to make fewer compensations later. Anyone have any input?
    Aug 2012
    SV, AZ
    447
    Proud of myself
    I have learned a ton over the last 4 days and I owe it to Dave Steck. Between the information I found on this website, google, and the couple little hints that Dave gave me through PM, I now have the knowledge and understanding necessary to convert injector information amongst the different generations of PCM. I can also apply these same techniques to other areas like filling in empty spots in a VE or MAF table. I'm sure there are other scenarios that I haven't thought of yet as well. It was absolutely a case of "Feed a man a fish vs Teach a man to fish." The information is out there already. It just has to be looked for. Thanks again Dave
    Anyway here is the file. It's a 2006 GTO E40 file with the injectors set up for GM#12609749. Applications found HERE
    50lbs flex injectors in E40.hpt
    This next attachment is one for GM# 12613412. Applications found HERE
    LY6 50lb injectors in E40.hpt
    Last edited by Eaglegoat; 04-11-2015 at 03:50 PM. Reason: Dave had the wrong data.
    Quote Originally Posted by Eaglegoat View Post
    Intresting Dave helped me with the same injector data however the numbers are off in spots. i might try your 12613412 file
    06 Grand Prix GXP, LS4-full bolt ons, Tuned by me
    Aug 2012
    SV, AZ
    447
    Let me know how it goes.
    Sep 2006
    Jacksonville
    109
    Thanks for posting this info! I picked up some of these 54lb/hr 6.2l flex fuel injectors (12609749). What is the difference between the two? GM#12609749 & GM# 12613412. The flow rate vs kpa tables are the same.
    05 Torrid Red GTO- TSP 418, DuSpeed intake, ported fast 102mm, nw 102mm tb, TXGiant v2 112lsa, AI 243 heads, Kooks 1.875 LTs, Kooks 3" Street Screamer, UDP, KAAZ w/ 3.73's, gforce aluminum ds, M6 swap, RXT.
    Tuner nathanhine1977's Avatar
    Oct 2019
    Darwin Australia
    52
    please do a data conversion for my E40 with these injectors GM#12598646
    LSA injectors
