Tune 1 with new ls7 injector data.hpt
edit: problem with left bank running lean?
Hi
The car: 2004 C5Z Time Attack race car. no street use. SD tune.
Goal: safe tune for road racing, max TQ down low, 6500RPM limiter
Please look over my tune and let me know if this is safe as a base file to fire up the car - will it even fire? And anyne know what wires do I splice into for the seperate IAT? I want to take out the LS6 MAF completely. edit: done thanks!
LS3 N/A Build engine: LS6 crank with 24 wheel and sensor, LS6 MAP sensor, LS2 cam gear and tan cam sensor, LS2 silver blade throttle body, LS3 intake and injectors, LS7 Airaid air intake with IAT sensor from a 2001 ls1 and NO MAF, LS6 knock sensors.
PRC Ported Heads - 358 CFM on the intake ports, 1 3\4 TSP long tubes, no mufflers, OEM compression and a 226/238 @ 605\612 lift cam.
All wiring adapters from Casper electronics.
The tune: I ran this base tune for 2 yrs with a 435RWHP heads and cam LS6. I found the LS3/7 injector data on the forums, please see if they are all correct. There is a NGK wide band permanenlt hooked up in the car.
please feel free to comment, i am by no means an expert
Riaan
