Cammed '00 Formula, 226/234 .598/.601 113+2 LSA (4 deg overlap), exhaust, LS6 intake, lid. At hot idle, ~200 deg ECT, my IAC count is ~10-20. I've got the set screw bottomed out (flipped for easy access, bottomed out to bolt head i.e. blade closed as much as possible). In addition I've also noticed my desired RAF is significantly lower other cammed cars, including my own Z06 which has a similar setup but with 243 heads. Lower than stock even, about 1-2 g/sec lower. I also have a weird issue where the car is slow to return to idle regardless of cracker or follower settings. With AC on and moving, it hangs at 1600 RPM for a few seconds when I disengage the clutch. Timing advance when it's hanging is what my main spark value is at 1600 rpm rather than the idle spark table, suggesting it's not going to idle conditions for a few seconds?
I'm starting to think it could be a vacuum leak? Going to pull the intake to see if anything is amiss but if someone has an idea I'm all ears.
Tune is attached, couple things need to be smoothed out but VE and MAF tables are less than 5% AFR error. On the log AC is on and you can see the idle hang at around frame 1133 using the russ k config.
edit - forgot to mention, with the set screw bottomed out my TPS voltage was still like .62v or something? I know I need it within .45-.55V so I'm guessing I'm going to have to slot my TPS screw holes?
